Rear wheel spacer
Old Aug 8, 2008 | 05:51 PM
beauschendel's Avatar
Default Rear wheel spacer
what causes my real wheel spacer to be loose when everything else is tight? my spacers have backlash...wount rotate snug with the wheel
Old Aug 8, 2008 | 07:25 PM
punkfish's Avatar
Default RE: Rear wheel spacer
is it the spacer on the sprocket side or the spacer on the rotor side? if it is the rotor side spacer make sure that it isn't the front wheel spacer they are similar in size.
Old Aug 8, 2008 | 09:54 PM
im pretty sure its on the sprocket side. but the wheel just moves side to side when i have it on a jack
Old Aug 9, 2008 | 08:54 AM
punkfish's Avatar
check to see if the grease seal is there, the spacer should fit snug. your wheel shouldn't move from side to side.
oxyg3ne
Feb 2, 2012 04:35 PM
ncsponger
Nov 13, 2009 10:07 AM
kpnupe
Dec 13, 2008 02:56 AM
peterk
Jun 19, 2006 11:20 AM
