Rear shock removal
ok so anyone planning on swapping an f4 or f4i shock......you will need a new kickstand.......my seat height is so much higher that the rear wheel could easily slip out while on the stock kickstand.....if you are taller like me this feels much better as far as comfortablility...allthough i dont know how the handling will be....but it looks sick..the tail sticks much higher
on an f4 or f4i shock should the end with the tube for the resevior be at bottom or top?
Can you adjust the ride height? You don't want that shock to be too long,you'll tuck the front too easily.
That's the preload adjuster, it will adjust the sag but that's not a true "ride height" adjustment, it'll just bottom out easier... That's my guess, I'm not a suspension expert though [&:]
