Rear rotors needed
Ok so changed put rear tire last night. Was cleaning up sprocket etc. And decided to check the rear rotor thickness aaand its past limit, as well as warpped pretty good.
Have any of u had experience with rotors off Ebay ie. Used or the Chinese off brands. I don't wanna spend 300 on full brake kit unless I have to
TIA
TIA
Arg, a rear rotor should never be in that condition. Not blaming you in any way. But I really wish people would learn to ride.
Anyway, on to the problem. I'd just buy a used OEM honda rotor off ebay. Should be cheap as there should be plenty of them in decent shape for sale. They aren't a high demand item.
I'd avoid the cheap knockoff stuff, well because it's cheap.
People buy Hondas because of the quality and reliability. I'll never understand why every repair and upgrade after that is done with cheap parts.
I bought used oem front rotors off ebay couple yrs ago they were all straight and well within spec thickness, today they are still going strong (and I ride hard every day) They came well packed in a pizza box, lol. Also recommend used oem its not like rotors expire
Hi there Im changing my rear rotor on a F4Y 2000 (not sure if its the same size as yours) soon and I'll have the old rotor
spare if you want it. Its in OK condition and has some life left in it (its is abit shiny and ridged as is expected)
Would probably need sanding, reconditioning. You can have it if you can cover postage costs. Cheers.
