Ram air
Old Aug 15, 2007 | 12:23 PM
avas_dad's Avatar
Default Ram air
I was wondering, I have been looking into trying to add ram air to my F2, I know the F3 ram air will not fit due to frame. Has anyone else looked into this? If so what ideas has anyone came up with?
Old Aug 15, 2007 | 01:46 PM
racer212's Avatar
Default RE: Ram air
More trouble than its worth for an F2... your jetting will go to ****.
That said, there used to be Airbox + kits from Factory and K+N. Havent seen one in many years, but if you can find one thats the best solution.
Old Aug 16, 2007 | 01:58 PM
Sand.Man's Avatar
Default RE: Ram air
I just did an airbox mod on my 93 F2 and it added a little bit of pep to the bike and a great sound from the airbox.
Take your snorkels and cut out the 90 degree bend and epoxy them back onto the airbox so they stick out about 3/4 of an inch.
Old Aug 16, 2007 | 02:35 PM
avas_dad's Avatar
Default RE: Ram air
Do you have a pic so I know how you put them back on?
Old Aug 17, 2007 | 09:45 AM
Sand.Man's Avatar
Default RE: Ram air
Also, I'm not sure about you but I had wicked vibrations rumbling through my bike, I fixed that by adding sticky sided foam strips to the rear of the airbox cover and to the 2 rails on the frame that the gas tank rests on... That stopped all vibration dead in its tracks!
Here are some pictures of the airbox
http://img516.imageshack.us/my.php?i...rinsiderc5.jpg
http://img528.imageshack.us/my.php?i...1170972mr9.jpg
Old Aug 17, 2007 | 09:48 AM
Sand.Man's Avatar
Default RE: Ram air
The only downside to this mod is that if you ride in the rain, some MIGHT get into the air box, I think there is a place for it to drain out though without getting sucked into the velocity stacks.
Old Aug 17, 2007 | 10:36 AM
avas_dad's Avatar
Default RE: Ram air
Do you still have that rubber cover still on there? Did it make a differance?
Old Aug 17, 2007 | 03:29 PM
Sand.Man's Avatar
Default RE: Ram air
Sorry, which rubber cover are you talking about?
I just cut down the snorkels to add a more direct airflow, the stock L shape draws in air from an area with no real direct airflow.
Old Aug 17, 2007 | 03:34 PM
avas_dad's Avatar
Default RE: Ram air
Their is a rubber cover to keep the heat from the engine there, its is right under where the snorkles came down to.
Old Aug 17, 2007 | 03:39 PM
Sand.Man's Avatar
Default RE: Ram air
Oh, yes leave that in place.
when you snip the snorkels down, keep the "bell" end though, you want the flare at the end so it draws air not only straight but from the sides as well.
