radiator fit
Old 07-03-2008, 02:28 PM
diabloCBR15's Avatar
Default radiator fit
So i was looking for an F2 radiator cause mine is pretty crappy, and was wondering if any other model radiators would fit the 91 F2. the F4i looks similar aside from the mounts, bt is that the only thing to worry about? cvause anyone can weld on new mounts for make a radiator fit. what else matters when fitting a radiator to the f2 cooling system? if the water pump can handle it? just ideas would be great. thanks
Old 07-05-2008, 01:42 PM
Default RE: radiator fit
no ideas people? come now... someone has to have thought of or done something for better cooling? F2 radiators are antiques!
Old 07-05-2008, 09:21 PM
I have a friend that is using a GSX-R radiator on an F3. it seems to work fine. Radiators should work fine for different bikes as long as they have the same size. I am not a mechanic but the concept doesn't seem to be more than a large surface area where the fluid is cooled down. i don't know
Old 07-08-2008, 11:19 AM
that is what i thought. but unfortunatley i already bought another f2 radiator. hopefully with no problems.. thanks for the thoughts
weston123
04-30-2013 06:30 PM
tpgpz
07-19-2010 01:00 PM
Cytotek
06-16-2010 11:10 PM
f3bika87
10-25-2008 08:09 PM
Quick Reply: radiator fit
