Project bike
#21
oh i got that picture off someones else's link its not my bike. i'm just trying to make sure i have everything. i know it sounds weird but the bike didnt even have the airbox to it so i'm just like making sure i have all the pieces or at least everything to make this damn thing run!
#22
Question to anyone who is actually reading this thread:
Just bought a speedometer cable because apperently this bike didnt have one. I then realized after i got it that it doesnt have the speedo gear thing that goes on the front wheel? My question is why in the hell would someone remove this??Dont want to know how fast there going or just to lazy after working on the wheel to hook it up,it baffles me?!
#23
Did the bike have a gauge cluster on it at all? Is it an F2 cluster, or something from an F3 or F4i, or some other model that gets the speedo signal from another source?
Post up some pics of the front end, from several angles, and maybe we can help out with ID'ing what you've got going on.
#26
Did you ever get some pics?
#27
i'm gonna deal with the speedometer issue another time. i have bigger issues. i have a leak at the oil cooler,you can see it 'sweating' coolant out at the seal where the cooler cover attaches to the cooler assembly. i mean it starts sweating or leaking as soon as i pour coolant into the radiator? i took the cooler apart and replaced the o-rings but not the big one around the cover. the gasket around the cover doesnt look bad but could it be the cause of leaking immediately out when coolant is added? and when i turn it on it leaks like a bastard! please help!
#28
Well, if you replaced the two round O-Rings inside the cooler, that's good, but that just prevents cross-contamination between oil and coolant, inside the assembly - the larger O-Ring between the oil cooler body and cover, however, is responsible for preventing coolant from leaking outside the assembly.
It's only $7, replace it, along with the ovular O-Ring gasket that seals the upper assembly to the coolant passages in the block (under $2), and then reassemble/remount the cooler to the motor, being certain to use a logical tightening sequence, and the proper torque settings for the bolts, so that things are buttoned up evenly and properly.
This should fix any leak there, unless the surfaces on the cooler's body and cover are damaged, or maybe warped due to them being tightened too much and/or improperly.
#29
Crap... two more things:
Firstly, the seals I'm talking about, are #'s 12 and 36 in this parts fiche:
CRANKCASE SET
Secondly,![Icon Worthless](https://cbrforum.com/forum/images/smilies/icon_worthless.gif)
![Big Grin](https://cbrforum.com/forum/images/smilies/biggrin.gif)
Don't sweat this leak, you'll get it fixed up quick and easy, don't worry.
CRANKCASE SET
Secondly,
#30
