popping on decel.
Old Jul 22, 2009 | 02:30 PM
fsjeeper's Avatar
Default popping on decel.
when my bike is decelerating the exhaust starts popping from about 7000 to 5000 rpm, i hate it and it just sounds terrible, is this caused by timing being out?, if so how do u check the timing. thanks.
Old Jul 22, 2009 | 02:37 PM
Dissevered's Avatar
I am having the same problem. Trying to get answers out of some pro tuners on another board at the moment. It is either needle jets or pilot jets that are too lean.
Old Jul 22, 2009 | 06:27 PM
anotheraznguy's Avatar
i have the same issue but i never linked it w/ being crappy. but then again my car also does that..
Old Jul 22, 2009 | 11:10 PM
fsjeeper's Avatar
well if either of u figure it out make sure u post it
Old Jul 23, 2009 | 12:05 AM
ckxtreme's Avatar
Are you running an aftermarket exhaust? If so, the jets in your carbs are the wrong size.
Old Jul 23, 2009 | 02:34 PM
cajunlowrida's Avatar
It's pretty much impossible for your bike to jump timing. The only way that would happpen is if the timing marks werent lined up on installation
Old Jul 23, 2009 | 03:30 PM
Dissevered's Avatar
check for exhaust leaks from your headers to the pipe. beyond that you are lean. Try turning pilot jets out in 1/2 turn increments.
Old Jul 24, 2009 | 02:49 PM
fsjeeper's Avatar
i have a D&D aftermarket exhause on it, also i do have a small exhaust leak on the manifold right near the head. so this may be a cause?
Old Jul 24, 2009 | 06:33 PM
Dissevered's Avatar
Definitely
Old Jul 24, 2009 | 06:55 PM
PlayfulGod's Avatar
Originally Posted by Dissevered
Definitely
+1 exhaust leaks are the #1 cause for popping exhaust. If its bad enough it could even damage a valve.
sergi037
Aug 28, 2010 01:06 PM
abelg
May 12, 2008 12:34 PM
SpecR
Mar 15, 2008 06:31 PM
birdstrike
Mar 25, 2007 03:14 PM
markcbr1100xx
Sep 24, 2006 11:40 PM
