Petcock
Old Feb 28, 2012 | 10:43 AM
BannWorthRulz's Avatar
Default Petcock
I just found out that my F2 has an F3 Petcock? What would be a reason that someone would do that. When I bought the bike, the owner told me I had to turn the fuel off when ever I stop the bike. Any specific reason I have to do that. Not used to these older model bikes.
Old Feb 28, 2012 | 11:46 AM
coalminer frank's Avatar
The f2 petcock was vaccuum operated. Bike not running = petcock off. The f3 had a fuel pump so if the bike was off so was the pump. F3 petcock on the F2 = no fuel pump and no vaccuum so its gravity fed so in order to keep the fuel from flowing into the carbs just in case your carb floats are over whelmed from the gravity of a full tank the petcock needs to be shut off when the bike is shut off so the fuel will stop from flowing into the carbs and into the cylinders and flooding it out. Something like that.
Old Feb 28, 2012 | 12:45 PM
JankCibberf2's Avatar
f2 petcock blows, f3petcock is awesome
Old Feb 28, 2012 | 01:56 PM
Default Ahhhh....
So turning off the fuel is good. Check. I appreciate the awesome knowledge, it really helps. Thanks
Old Apr 13, 2012 | 10:28 AM
rafa2210's Avatar
I know this thread is kinda old,
but I have an F2, and I can have the petcock opened, and no gas will go through unless I start the bike.
Does that mean I do not need to turn it off when I park the bike, even overnight or for a few days?
Old Apr 13, 2012 | 10:36 AM
estate4life's Avatar
February 2012 ROTM
Funny thing is that they do sell oem fuel pump for the F2...what are the chances PO install a fuel pump??
Old Apr 13, 2012 | 10:57 AM
74demon's Avatar
the f2 one is vacuum operated. it needs vacuum from a running engine to flow. you dont need to turn it off, but its not a bad idea to if its going to sit for awhile. a little extra safety never hurts.
1992 gsx600f
Mar 10, 2011 12:57 PM
jestr
Feb 15, 2009 11:06 PM
tazshido
Feb 25, 2008 01:56 PM
cbrboyze
Nov 9, 2007 07:54 AM
