oil problems
Old 02-03-2008, 10:12 AM
tao_victim's Avatar
Default oil problems
i went on a trip for a few days and when i came backi started up my bike, but the engine had rattling coming out of it and the oil light was on. i turned it off immidetly and checked the oil levels.
oil levles looked good, the oil filter was on snug, and the oil plug was on tight but it did have some oil around it, so maybe a little leak there.
anyone have any other ideas to toss into the mix so i know where to look?
Old 02-03-2008, 10:19 AM
kjohnson's Avatar
Default RE: oil problems
Where within the motor is the rattling coming from?
Cylinder head?
CCT?
Bottom?
Do you do wheelies?
Old 02-03-2008, 11:35 AM
tao_victim's Avatar
sounds to me as if its coming out of the cylinder head, i dont really want to turn it back on and check if you know what i mean.
and thats a negitive on the wheelies.
it was running smoothly before i left and when i came back 3-4 days later its having this problem.
so i dont know how anything could be broken.
maybe water got in it or it clogged?
i leave my bike outside under a motorcycle cover.
Old 02-03-2008, 12:58 PM
tao_victim's Avatar
im going to replace the oil and oil filter, hopefully itll fix.
Old 02-03-2008, 02:40 PM
tao_victim's Avatar
oil change didnt fix it.
the oil levels are good, the filter is new and not clogged. no water or coolant in my oil, idk whats wrong with it, how can this happen in three days of not even using it?
anyone have ANY ideas or solutions?
give me some more info on the cct also. what does it sound like if it goes bad and what does it do exactly? or how would it have gone bad?
Old 02-03-2008, 03:58 PM
kjohnson's Avatar
You'll have clattering on the riders' right side of the motor when the cct goes bad.It's common on Honda CBRs and is a 50 dollar fix.
Old 02-03-2008, 09:32 PM
If you are worried about the engine starving for oil you can pull the valve cover and see if there is oil pumped to the top of the head while trying to start the bike. if so then the oil pump is working and the internal parts should be adequately oiled. Hope its not a catastrophic failure in the engine, but if so atleast the damage hasnt occurred under power destroying the entire engine. Good luck.
Old 02-04-2008, 01:19 AM
tao_victim's Avatar
turns out the clicking was coming from the valve train.
and it just fixed itself?
maybe it just took awhile to push the oil up into the valves?
anyways, shes running good again.
Old 02-04-2008, 01:36 AM
Sand.Man's Avatar
Do you have the stock cam chain tensioner? (have you ever replaced it?)
It's probably on its way out... Look up an APE CCT on eBay, get yourself one for $50 and catch it before it gets really bad and annoying...
Old 02-06-2008, 12:12 PM
tao_victim's Avatar
i bought the bike used with 14k miles on it and i personally havent replaced it, so im sure its the stock one.
how can i tell if its about to go out? does it make a certain noise or have an off feel while riding?
Quick Reply: oil problems
