OIL LEAK! streaming out hole
Old 04-13-2013, 08:48 PM
LowriderLo$89's Avatar
New Member
Default OIL LEAK! streaming out hole
My bike was running fine after valve adjustment for a week now but this morning when i went to warm it up i noticed a lot of oil seeping out from the header area. After removing all the fairing i noticed that there is a small hole on the cylinder head below the exhaust port( 4 holes along the head 1 under each exhaust port) the oil is only coming out of the hole closest to the cam chain side not out of any of the other 3 holes. I am stumped to what it can be other then excessive oil pressure causing it to spill out. It runs perfectly fine other than the major oil spilling out, when i arrived home last night didn't have this issue and no oil marks on the ground. Any hints???
Old 04-13-2013, 09:46 PM
gpfan1's Avatar
Check out this link in the forum.
https://cbrforum.com/forum/f2-tech-9...n-know-114262/
Internal valve cover gasket is misaligned allowing oil into spark plug tubes. Little hole lets out oil.
Old 04-15-2013, 08:43 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
GPFan1's right on the money - it's just a weep hole, to ensure fluid of any sort, isn't pooling around the plugs - did you torque all the bolts to spec, and use a good torque sequence?
If by any chance, all you did was tighten all of the bolts down, not using the proper torque value (7 ft. lb, if I remember correctly), you might just luck out with loosening everything up, and torquing to spec... with a torque spec so low, if you did just tighten them down, it would be very easy to over-torque these bolts.
robhbest
08-29-2013 09:45 PM
bfisch2
05-31-2011 11:57 AM
antatious
05-14-2011 10:02 PM
jamesbfg
06-14-2009 05:06 PM
Dr.Fingers
09-23-2008 10:01 AM
Quick Reply: OIL LEAK! streaming out hole
