Now the Front Brakes
Old Apr 22, 2008 | 08:36 AM
spdbump36's Avatar
Default Now the Front Brakes
So, yesterday I went out for a spin and everything was fine and dandy till i started to loose brake pressure. Went home and began to bleed the front brakes. The left side, no bubbles. The right side had no bubbles in the bleeder screw but there was bubbles coming from the MC Banjo bolt. I kept bleeding and bleeeding and bleeeeeding and still bubbles. I looked to see if there was any damage to the lines and at the top it looked like they were beginning to rust on the couplers (there steel braided lines) and the protective rubber was starting to peel back. Would this be enough to allow air to enter the system or should i just keep on trying to bleeeeeeed the front right caliper/ MC banjo bolt.
P.S I do have another set of steel braided lines so should i just throw those on and yeah.
As always thanks
Kevin
Old Apr 22, 2008 | 09:28 AM
Ayres_08's Avatar
Default RE: Now the Front Brakes
Definatly throw on the other set of brake cables. Should fix ur prob.
kdbolt70
Jul 3, 2012 12:55 AM
AlexF4i227
Mar 15, 2011 09:05 PM
KenG
Aug 31, 2010 05:20 PM
95HondaCBRF3
Sep 4, 2007 04:10 PM
brian97
May 8, 2006 10:45 AM
