new tires
Old 03-24-2008, 03:16 PM
mufinkrakr's Avatar
Default new tires
Hey everyone i'm in need of new front tire. i had my rear one replaced a few weeks ago and got a maxxis tire i really like the feel and the easy turning. does anyone have a suggestion on the front tire? my mechanic has quite a few tires around the same price but he doesn't have any personal suggestions.
Old 03-24-2008, 06:00 PM
Default RE: new tires
I just bought a metzler tire from denniskirk.com... go there enter the year and model of ur bike and it will show u a few different types of tires that are made to fit ur bike. i just took my bike out for a ride the other day and i loved the tire and the way it handled
Old 03-24-2008, 08:43 PM
smitty911's Avatar
I like the pirellis. just put them on this winter and they warm up a lot faster than my other tires and i could lean way farther than before.
Old 03-30-2008, 01:54 AM
mufinkrakr's Avatar
well i decided on getting a pirelli diablo tire. i had read some interesting things on the tire including that it has a steel band, supposedly stronger fibers, and the warm up time is very quick. Well after all was said and done with tire purchase and install was about 130 so not too bad, i did notice a big difference between the old worn down bridgestone tire and the new tire. i did about 8 circles in each direction to wear off that silicon then hit the freeway. i took it pretty easy but the ease of turning with just the slightest weight shift got the better of me and i ended up taking a few corners at what some would consider questionable speeds... haha. the true test is going to be on my trip this weekend, im headed down south towards tucson and am going to be taking a scenic windy route. i'll let you know how she does.
Old 03-30-2008, 11:10 AM
Sand.Man's Avatar
You're not supposed to mix and match tires.
Every tire has a different profile, and are designed to work with their matching partner tire.
If you push these tires hard, there is an increased risk of a crash.
I'll also note that you should not use Maxxis tires on a streetbike, many many bad reviews... They're best saved for dirtbikes and lawnmowers.
Be careful, maybe see if your dealer will take that Maxxis tire back on trade for a new Pirelli...
Old 03-30-2008, 11:14 AM
Sand.Man's Avatar
Oh, P.S., for all you guys that notice the incredible handling that your new tires have over your old ones...
Your old ones at some point in their life had the same effect.
It's just that they get squared off (flat profile) after so much usage.
To prolong the life of your tires, check pressures religeously, 34F/36R works well.
The new ones feel great because they have the proper air pressure, and a fresh profile!
Old 03-30-2008, 01:44 PM
mufinkrakr's Avatar
ah, was not aware of that....[:@] well i'll just have to take it easy, i have a side mechanic and he wont trade out the tire for me.
Getz2003
05-31-2009 01:35 AM
Exitwounds
10-28-2008 07:18 PM
Greyfox5
07-04-2007 01:56 PM
barryem
05-14-2007 02:12 AM
barryem
04-11-2007 10:42 PM
Quick Reply: new tires
