need help with cbr!
Old Nov 10, 2008 | 11:58 PM
93cbr600's Avatar
Default need help with cbr!
i have a 93 cbr and when i twist the trottle hard while riding it will rev high in the rpms and catch when i let off a little bit. It seems to do it more in the lower gears, it will jump from like 4000 to about 8000 real quick when i try to take get on it. anyone have any ideas of what it may be?
Old Nov 11, 2008 | 12:10 AM
Sand.Man's Avatar
Default RE: need help with cbr!
Your clutch is slipping badly.
Old Nov 11, 2008 | 12:21 AM
93cbr600's Avatar
Are repairs costly? What about the clutch basket? would it be damaged?
Old Nov 11, 2008 | 01:07 AM
Sand.Man's Avatar
$90 for clutch plates and springs + the cost of a gasket gasket, check the clutch basket fingers for grooves when you have it out, but that causes a sticky clutch not really a slipping one.
Old Nov 11, 2008 | 06:18 PM
93cbr600's Avatar
any certain brands to buy or stay away from? found a set of EBC on ebay for like $60 shipped.
Old Nov 11, 2008 | 06:45 PM
ggrahn's Avatar
Make sure you measure and/or replace the springs as well. Follow the service manual for specifications. There is a reason they are there.
Old Nov 11, 2008 | 07:08 PM
Sand.Man's Avatar
I use the EBC SRC series clutch set, it comes with the fiber plates and new springs.
It's designed for heavier sportbikes (f2 is pretty beefy), faster riders and production based race use.
bikebandit.com has them for about $100
http://www.bikebandit.com/product/A4661106
Be sure to soak the new plates in oil before installing.
Old Nov 12, 2008 | 12:42 AM
elmer's Avatar
Sounds like your clutch is either whacked out of adjustment or completely effed. Even if its just adjusted poorly, all that slipping has probably trashed the clutch entirely. the discs are probably fine so long as they aren't warped, but you'll need a set of fibers and a set of springs. Then you should be set.
