My new Toy
Old Oct 20, 2007 | 07:00 AM
phishstyx's Avatar
Default My new Toy
Well here she is.
$500 well spent I think
And after removing a few things
Bike is in a few more pieces now, I am doing a valve check this weekend to it, but regardless she does fire up if I throw everything on her.
And now to order some parts. I have the radiator, throttle controls, gauges, fairing stay, and seat coming. Should all be here by next weekend. Then after that it's race plastics, rearsets, Pazzo levers, steering damper, SS lines, and 520 with -1 +2 gearing.. All should be done by January I'd say.
Old Oct 20, 2007 | 03:56 PM
eweppley's Avatar
Default RE: My new Toy
Good luck! Looking forward to seeing the "after" pix.
Old Oct 20, 2007 | 04:33 PM
EHonda's Avatar
Figure I'd help you out.
Old Oct 20, 2007 | 06:23 PM
FNQuickF2's Avatar
Good luck with her!
RB
Old Oct 20, 2007 | 07:18 PM
phishstyx's Avatar
Ok so I need a little help here. I just put a new throttle(right hand control) on and whenever I twist it, it does not snap back. Whatdoes this mean? The actually metal bar that the contol is on is slightly bent, could that have something to do with it, or is it just a throttle body issue?
Thanks
Brad
Old Oct 20, 2007 | 07:26 PM
Sand.Man's Avatar
adjust your throttle cables, they're sticking, they are adjusted at the carb
Old Oct 20, 2007 | 07:44 PM
phishstyx's Avatar
Thanks for the info.
Ok so how exactly do I adjust the cables?
Sorry
Old Oct 20, 2007 | 10:45 PM
woo545's Avatar
You can clean the cable too....extend the cable all the way out and use a little steel wool to get the grime off. Then place some cable lubricant on it.
