A little change..
If any of you remember my old thread of my bodywork fab, I changed the F2 from this:
![Name: l_40004a2ef11b4bf28767a92c351058a3.jpg
Size: 41.5 KB](https://cbrforum.com/forum/attachments/cbr-600f2-16/43865d1501282411-little-change-l_40004a2ef11b4bf28767a92c351058a3.jpg)
To this:
![Name: cbr.jpg
Size: 98.9 KB](https://cbrforum.com/forum/attachments/cbr-600f2-16/43866d1501282411-little-change-cbr.jpg)
Painted and fabbed myself, this winter I decided to hold off any major projects with the supra and change up the bike a bit more. My current plans are to swap the 900RR motor in, a 954RR front end (forks, wheel, brakes, and controls), and maybe the VFR SSSA if time and money allows.
This previous Friday I made a drive to pick up a 900 motor, should only have 1,600 miles on it since the rebuild. Currently has an aftermarket clutch, polished covers, and a few other goodies.
![Name: 900RR.jpg
Size: 57.0 KB](https://cbrforum.com/forum/attachments/cbr-600f2-16/43867d1501282411-little-change-900rr.jpg)
Now all cleaned up:
To this:
![Name: cbr.jpg
![Name: 900RR.jpg
Now all cleaned up:
![Name: HPIM1475.jpg
Size: 80.8 KB](https://cbrforum.com/forum/attachments/cbr-600f2-16/43868d1501282411-little-change-hpim1475.jpg)
Sorry got rid of those last year.
How the heck is the F2 harness going to work with a 900 ecu? I dont know. Do the ecu's have the same plugs where they plug in to the wire harness. Maybe the ecu have the same part number. On a side note I have a stock 09 R1 complete exhaust that might work. Its titanium. If every thing works out maybe I'll put a 900 engine in my F2. Which would actually be kind of stupid since I have a 08 cbr 1000 anyway. But it would still be cool as hell.
Ill be using the f2 ecu also, I talked to a guy running the 900 in his f3 and used his f3 harness and ecu with no issues
Thanks baron! As far as the speedo goes im currently running the f4i cluster so my speedo is driven off the front sprocket with a 900rr sensor and a speedo healer. My temp gauge is a sensor from a 929 that ill also be transfering to the 900 motor
