A little change..
4 Attachment(s)
If any of you remember my old thread of my bodywork fab, I changed the F2 from this:
Attachment 43865 To this: Attachment 43866 Painted and fabbed myself, this winter I decided to hold off any major projects with the supra and change up the bike a bit more. My current plans are to swap the 900RR motor in, a 954RR front end (forks, wheel, brakes, and controls), and maybe the VFR SSSA if time and money allows. This previous Friday I made a drive to pick up a 900 motor, should only have 1,600 miles on it since the rebuild. Currently has an aftermarket clutch, polished covers, and a few other goodies. Attachment 43867 Now all cleaned up: Attachment 43868 |
Yes, I remember. Your gonna put the 900 motor in your F2? Please post lots of details and problems you encountered along the way. Your gonna need a wire harness also and custome exhaust.
How much for your old fairings'
Originally Posted by coalminer frank
(Post 1104503)
Originally Posted by JankCibberf2
(Post 1104512)
Nooooooooooooooo
How the heck is the F2 harness going to work with a 900 ecu? I dont know. Do the ecu's have the same plugs where they plug in to the wire harness. Maybe the ecu have the same part number. On a side note I have a stock 09 R1 complete exhaust that might work. Its titanium. If every thing works out maybe I'll put a 900 engine in my F2. Which would actually be kind of stupid since I have a 08 cbr 1000 anyway. But it would still be cool as hell.
Hard to forget your bike it looks fantastic:).
Sounds like a great plan for power and handling, Will the 954 forks be a direct fit, and what will you do with the Speedo? |
Ill be using the f2 ecu also, I talked to a guy running the 900 in his f3 and used his f3 harness and ecu with no issues
. Thanks baron! As far as the speedo goes im currently running the f4i cluster so my speedo is driven off the front sprocket with a 900rr sensor and a speedo healer. My temp gauge is a sensor from a 929 that ill also be transfering to the 900 motor |
2 Attachment(s)
Got one of my pieces back from powdercoat, the frame will also be this color
Attachment 43619 And got my header in.. Attachment 43620 |
Dang, I wish I had the time/money to make my F2 look that good.
