Just Pushed my bike home, need help plz
Old Sep 15, 2011 | 12:59 PM
  #21
JesseAwesome's Avatar
Originally Posted by woo545
Was the gasket sealant and attempt to fix a like or something...'cause it's not needed. Worse if the sealant broke off and ended up in the cylinder.
+1
That **** has no business being there...
Old Sep 20, 2011 | 10:05 AM
  #22
MikeInCtown's Avatar
So the bike is up and running again? Thats good news. The plugs didn't look good and I suggest replacing them. I think Autolite plugs #4303 (IIRC is the number) work just fine. I put them in my bike while i was working on the carbs as they were $2 each. Bike runs great now. Also, one thing to watch out for is getting the tank vent line kinked when you put the tank back on. make sure you get down on your knees and look at the hose to make sure. mine was routed in the proper frame passage but even then it was kinked. i realized it and heard a hiss of air when I pulled it straight. no more stalling issues. lol
Old Sep 20, 2011 | 02:52 PM
  #23
JankCibberf2's Avatar
^^^right on, if those autolites end up working good for you lemme know, i have those ngk's in right now and they are certainly not worth 11 dollars a plug. i had that stupid kinked issue from the petcock to the carburetor blocked a while ago but replaced that line for free from orielys lol, they just said take it
Old Sep 13, 2016 | 06:13 PM
  #24
Webbie1's Avatar
For all I know, my bike may have been like this ever since I got it and it took this long to drain the battery down to where it wouldn't start the bike anymore. Because I do get some voltage to the battery and it does increase at higher reps so maybe it's just slowly draining the battery and it'll go another twenty-five hundred miles before it drains it again?
Wranghondo
Apr 9, 2014 10:47 PM
Yellow900
May 13, 2011 08:50 AM
bong0
Mar 24, 2011 01:40 PM
jutsin
Nov 7, 2008 07:24 PM
buckd44
Apr 22, 2008 12:42 AM
