Jumping Out Of Gear Around 5K RPM
I'mjumping out of 1st and 2nd into neutralaround 5K rpms - other gears will ride right up the tach. Troubleshooting in the manual suggests that the shift fork might be bent. But I'm open toideas as to what else might be causing this before Ipop open the transmission and disable the bike for a while.
Anything else you guys think I should check out first?
There's no harm in riding it like this for a while, is there?
Thanks,
rey
Thanks,
rey
RE: Jumping Out Of Gear Around 5K RPM
i've had the same problem with my f2, if you hold your foot up it stays in? everything is pointing at shift return spring as stated above on mine, but its a royal beotch to get to. i haven't tried yet, took the clutches out and said "mmm...maybe later".
