Interesting problem - chain tightens itself
Old Apr 23, 2007 | 12:09 AM
Syphen's Avatar
Default Interesting problem - chain tightens itself
At first I thought it was because I wasn't tightening down the axel enough, but 3 times already I've had to loosen the chain because after riding for a day or two it will be right back right with about 1/2" play in it. Cannot figure out why its doing this. Any ideas?
Old Apr 24, 2007 | 01:01 AM
bmg velocity's Avatar
Default RE: Interesting problem - chain tightens itself
My guess would be not adjusting it correctly in the first place...
If you check several spots of the chain for slack, and you get different measurements, your chain needs a bath in some good cleaner...then a ton of lube...re-intsall and adjust.
Or you may need a new chain.
Or...you didn't tighten the adjusting threads and axle nut correctly.
Old Apr 25, 2007 | 08:58 AM
Syphen's Avatar
I just ordered a new chain & sprocket set. Enough screwing around with this one. Vortex 520 conv. 15/45 w/ a gold chain.
EViR
Nov 12, 2012 04:24 PM
EViR
Jul 4, 2012 06:49 PM
jfreak16
May 11, 2012 06:08 AM
Brian425
May 19, 2010 10:37 AM
toastyf4i
Nov 7, 2009 11:26 AM
