Integrated tail light
Old Aug 6, 2007 | 07:00 PM
madgreek's Avatar
Default Integrated tail light
My bike has a stock taillight that has been converted (with a trailer harness) to act as the turn signals also. My problem is, when I hit the brakes while signaling, the bulb flashes fast (until I let off the brake). Does this mean that I have the wrong bulbs in, or is the problem in the wiring?
Old Aug 6, 2007 | 10:17 PM
jaghunter's Avatar
Default RE: Integrated tail light
wiring, at least I beleive so.
Old Aug 6, 2007 | 11:01 PM
BlkF2's Avatar
your wiring may be bad, or you may need resistors to take up some of the extra juice
Old Aug 7, 2007 | 05:25 AM
madgreek's Avatar
does anyone know of a schematic that shows what the wiring should look like?
Old Aug 7, 2007 | 07:12 AM
felk27t's Avatar
I have one...I don't care for it, so I picked up a set of turnsignals that attach to the license plate holder ($16 off ebay)...the trailer adapter should have the terminales labeled... regardless, here's the wiring diagram.... http://www.1tail.com/motorcycle_part...iagram_UIT.pdf
Look into picking up a set of turn signals... http://cgi.ebay.com/ebaymotors/suzuk...2090QQtcZphoto
(not my auction)...but a good product
Old Aug 7, 2007 | 07:34 AM
madgreek's Avatar
felk,
What don't you like about it? I think the look is great, but the light visibility leaves something to be desired. All of the turn signal kits I have seen are just the opposite. (visibility good, look bad) Also, the one you showed probably wouldn't fit my bike unless I mounted them about mid plate or lower b/c I vhave my plate squeezed into the space(with a little modification) directly under my taillight.
Old Aug 7, 2007 | 07:57 AM
felk27t's Avatar
visiblility sucks...hard to tell turn signal is flashing...when i bought my bike it didn't have the "factory" tail light and license bracket (home made fender elliminator)... Ipicked up a little bracket that mounts to the under side and a $2 led light...i drilled a hole in underside and mounted led, mounted bracket just behind led and the turn signals to the bracket...It look very clean, except the butcher job that the last guy did on the fender...bike is at shop getting bearing replaced in fork and a new tire...otherwise I'd post a picture...
Old Aug 7, 2007 | 01:05 PM
FNQuickF2's Avatar
I got the plate signals...They are LP(LockhartPhillips).Surprisingly bright for so small.Very easy to install and no problems with the rate of blink either.
RB
Old Aug 7, 2007 | 01:16 PM
madgreek's Avatar
I'd like to give it a shot. I'll look around for some clear ones b/c my signals are clear up front. Also, I'd like to find a nice clear taillight too, so that I can get rid of the painted taillight. It was already painted when I got the bike, so I had to do it again. Turned out ok (for a ghetto-*** painted taillight)
FightasCBR600
May 26, 2011 09:09 PM
ZFRED10
Apr 18, 2011 02:24 AM
adrianinflorida
Aug 6, 2010 04:25 PM
BRRandoVando
Mar 6, 2009 11:58 AM
muffinman
Jun 21, 2005 09:54 AM
