Indiglo Guage Faces for F2s?
Old Apr 4, 2006 | 11:05 PM
v1perfan's Avatar
Default Indiglo Guage Faces for F2s?
Hi All,
Has anyone changed their guage faces from black to white on their F2? When I was prepping my bike for this season I had the dash apart and noticed 5 of the 11 bulbs were shot (I never had the cluster apart before). I was going to replace the bulbs with LEDs, and I saw the blue LEDs for the same price. I assume the blue lights would look silly under the black faces, so I looked into white faces for an F2. No dice.
Any ideas, or should I just switch all the 158s to super white LEDs instead?
Thanks!
Old Apr 6, 2006 | 03:52 PM
jbrooksF2SuperSport's Avatar
Default RE: Indiglo Guage Faces for F2s?
how difficult is it to take apart the gauges? i ride to work and that means riding home at night often. i would like good bright gauges too. what was involvled in opening up the gauges?
Old Apr 6, 2006 | 08:53 PM
v1perfan's Avatar
I didn't get as far as taking apart the guages ( yet! ). I only removed the instrument cluster and looked at the bulbs.
Old Apr 9, 2006 | 01:55 PM
1998f3's Avatar
Its easy on my 98 f3. Last saturday, i put a new headlight bulb in, put a new speedo in, hooked up my leds, and drilled holes and installed my frame sliders. All in a matter of 5-6 hrs. I was just taking my time too. Just take off all the fairings. Everything on the front too. There are no shortcuts here. There are 3 bolts holding the cluster in place, as well as the 2 wiring harnesses in the back. After that, there are I think 8 small screws holding the speedo in place. If you are just replacing the bulbs, then you dont have to take the speedo out of the cluster, just unscrew the bulbs in the back and put the new ones in. Most time consuming part is remembering where all the fairing bolts go. All in all, its pretty easy.
Old Apr 23, 2006 | 01:17 AM
2muchspl's Avatar
NO dont use the leds, they will be useless- i recently sold my F2, with that mod -and the only use of the bulb(s) is to light up the needles- just use 194's ther are super bright and will out shine ANY LEd that you can buy- I can go take pics of my old F2 if you wanna see...
Old Apr 23, 2006 | 09:54 AM
gride99's Avatar
Id like to see some pics if you have them handy.
ORIGINAL: 2muchspl
Old Apr 23, 2006 | 10:01 PM
2muchspl's Avatar
no problem, I've been dying for a reason to go see my former flame. give me a day for pics of the gauges , heres a couple of pics
mods: new paint, re covered seat, flush mounts front and rear ( front molded sigs cutout and re molded flat), fender eliminated, polished clutch/stator cover,levers,pegs and bracket,forks, valve cover, 16 piece blue LED kit, silvania silverstar, smoked screen, reverse gauges, clear taillight with RED LEDs, new 208s, new RK chain with Vortex sprocket,Jardine, rear seat cowl.
SOLD IT FOR $2500.00, MY NEW TOY IS THE 954RR
[IMG]local://upfiles/6525/A77971B0C42D40718E788A797154C834.jpg[/IMG]
[IMG]local://upfiles/6525/06029E3CA30D4E6CBABB7B3169C29982.jpg[/IMG]
[IMG]local://upfiles/6525/82EAB46F884E4FC0A98A43E99CF5877D.jpg[/IMG]
akrite
Sep 30, 2013 02:22 PM
Juliet
Nov 1, 2009 09:41 AM
oldschoolCBR
Nov 20, 2007 06:50 PM
TheX
Dec 27, 2006 01:50 PM
