Help in regards to Carbs
Old Jul 18, 2020 | 07:47 AM
Damir Ismagilov's Avatar
Default Help in regards to Carbs
Hello CBR community,
I haven't ridden in a while and its time for me to re-sync the carburetors. I pulled them off cleaned them and bike started right up. I am now facing the issue of finding where to connect the manometer. I've found 3 nipples on the motor head (cyl 2,3,4 from right to left) under the carburetor but where does the fourth one go (for cyl 1).?
I've searched the forums and couldn't find this thus decided to make a post asking for your help. I've attached a photo with a pencil pointing at the 1st cylinder which I am referring. Thanks ahead of time and ride safe, - Damir
to.
Old Jul 18, 2020 | 08:41 AM
Carb #1 is different for some reason. It has a srew where you are expecting a nipple.
Old Jul 18, 2020 | 08:47 AM
Where is the screw itself? I've been looking and couldn't find it. I got clymer manual and it's shows it on the diagram but there isn't one. I can take more pictures if required. Any suggestions would be awesome!
Old Jul 18, 2020 | 08:52 AM
It should be the same place as the nipples
Old Jul 18, 2020 | 08:53 AM
The nipples protrude. The screw dosen't.
Old Jul 18, 2020 | 09:52 AM
Is this the screw? Does the adapter plug into this? Or do they go into carbs 3/4? Thanks for everything
Old Jul 18, 2020 | 10:44 AM
Yep, that's it.
Old Jul 18, 2020 | 11:26 AM
Thanks for your help! Ride safe, hopefully i will be riding soon as well! Best of luck -Damir
Old Jul 18, 2020 | 11:48 AM
You got it. Glad to help. I have no idea why they made that one different.
Old Jul 18, 2020 | 09:48 PM
I had issues with this back four years ago, and im glad you came to help! People like you make this world a better place, thanks brother! I will try to help others who face similar issues. If ever need anything let me know! i am usually good with electronics and stuff as such however after losing the manual after moving and not touching the bike for many years I've forgot about that little son of a gun. I believe a gentleman named Frank has helped me previously, so thank you and him if he ever reads this! Best regards, -Damir
91600f2
Apr 4, 2008 01:39 PM
pahurricane
Oct 28, 2007 08:24 PM
wussola
Jan 8, 2007 04:17 AM
valvercorsa
Jan 8, 2006 02:08 PM
