RE: HELP ME PLZ!!! Wont start at all..
How goes the carb cleaning?
Well just takin a short break,umm so far so good, there was still some rust in em even after i flushed em, but thatwas kinda a givin. Now that Iv got it all clean and ready too go back together, you know what ill be doin. lol But ya ill keep you guys updated. Thanks again guys!!
Well I got them back together, got her started, took her for a spin got back and noticed there was alot of white smoke comming out the pipe. Idono, i dont want to give up butmaby i should sell it and let someone that know what there doin fix it??? lol
I wouldn't give up yet - that white smoke could just bethe rubbing alcohol.
Did it seem to run any better or worse? I'd get somefresh gas in there and you really might want to get some sort of gas tank sealerso it doesn't start rusting again. |
If all else fails go to a Honda mechanic.
That should do the trick |
Is it whitish blue or just white? Does is have a smell of oil to it?
Whitish blue is most likely oil. I'd say Headgasket. But could be a ring on the piston (I'm guessing, but I'm not sure, that checking the compression might help determine a ring issue. If it's white, does it stop after some time? Might be condensation built up in the exhaust system. If it continues on, then probably the headgasket. Does the water level in the radiator (or resevoir) go down. I'm not a mechanic...these are just my guesses. Someone else might have better ideas. |
