HELP ME PLZ!!! Wont start at all..
Hey guys whats up? Im new here and just got a 94 cbr 600 f2. Well the problem is that It wont start, It had been sitting for a while soI tooka look in the gas tank and it was rusted bad. So I took the tank off cleaned it really good, cleand the petcock, and flushed the carbs really good to, then checked for spak got that on all plugs, put it all back together and still wont start. [sm=smiley24.gif]Any ideas what might be the problem? Thanks in advance!
RE: HELP ME PLZ!!! Wont start at all..
If you hit it with some starter fluid, does it start temporarily? And +1 on the cleaning the jets with a fine piece of wire (make sure you don't make the holes larger then designed). I personally have trouble starting my bike when it is cold. I have not taken the time out to take it apart again to check if they choke cable is adjusted correctly. When it is cold, it usually takes me 10 minutes to get it started....crank..start dies...let sit for 10 secs, readjust choke, rinse and repeat.
Well my step dad is a ford tech and he told me to flush the cabs with a little bit of rubbing alcohol and then carb cleaner. I would take apart the carbs butI dont know how to synchronize themafterI put em back together.Do you think the rubbing alcohol was a bad idea? Im gana go try some starter fluid and see if it will even backfire. Thanks Guys!
Well I found the problem, now I kinda fell like anDUMB A$$ lol. It was the main fule line it was kincked so I replaced it. Now it runs, but..... when I give it gas it kinda dies befor it will go, any ideas?? Thank you for all the help and suggestions!!
