Help Carb!
Old Mar 21, 2013 | 03:55 PM
denbiker's Avatar
Registered Users
Default Help Carb!
Hi all! tell how long should be the spring on the diaphragm in the carburetor! PC-25!I do not know what to do already!the sudden opening of the throttle failure, motorcycle jerks(Sorry, I'm from Ukraine)
Old Mar 21, 2013 | 07:08 PM
CorruptFile's Avatar
June 2013 ROTM
Have the carburetors been balanced? Are all 4 springs the same length? Have the carbs been cleaned?
Old Mar 22, 2013 | 03:19 AM
denbiker's Avatar
Registered Users
All four springs of the same length! synchronized and cleaned, I am two years nothing I can do about it
Old Mar 22, 2013 | 03:35 AM
denbiker's Avatar
Registered Users
How do the spring to ride a motorcycle?
Old Mar 24, 2013 | 07:40 AM
denbiker's Avatar
Registered Users
Help help help
Old Mar 25, 2013 | 01:53 PM
subyman1440's Avatar
Valve adjustment is the only thing that comes to mind if the carbs are already tuned. But it sounds like they are not synced properly. If it stumbles and hesitates when you whack the throttle, it's most likely synchronization. I can't think of anything else. Check your Air fuel ratio?
LJ Harp
Jan 18, 2011 10:49 AM
patrick12
Apr 9, 2009 12:49 PM
Whitehead
Mar 22, 2006 12:35 AM
