carb and jet help
Old Apr 8, 2009 | 03:29 PM
patrick12's Avatar
Default carb and jet help
I have a 99 cbr f4. As of now everything is original except for a scorpion slip-on. I need to clean the carbs and replace the plugs and i wanted to know if i should do anything with the jets. The bike still has some power but i cant get the front end to pick up unless i drop the clutch and high rpm's (i dont really need to pick up the front end but i want the option and i dont want to change the sprocket).
Any ideas on the subject would be greatly appreciated.
Thanks
Patrick
Old Apr 8, 2009 | 11:26 PM
brveagle's Avatar
i'd personally get the carbs cleaned and new plugs in there... and then ride it. Don't be too haste in jetting changes. Most often a simple slip on is not gonna warrant a jetting change.
Old Apr 9, 2009 | 12:49 PM
patrick12's Avatar
thanks
someone told me i could put bigger jets in but they also said to check to see if anyone else has done anything
LJ Harp
Jan 18, 2011 10:49 AM
tatmike
The Hurricane Saloon
Nov 4, 2009 01:50 PM
Whitehead
Mar 22, 2006 12:35 AM
