Headlight is out!!!!????
Old Jul 1, 2009 | 05:46 PM
jfornoff's Avatar
Question Headlight is out!!!!????
i went on a ride and shut my bike off went inside, came back out to leave and the headlight wouldn't work. i checked the bulb and it was good replaced it anyway. can not find any reason why it happened. no loose wires in the harness, nothing grounded out, the fuse is good. the high beam indicator also dose not work. i am not getting current to the bulb. i am getting a lot of resistance through the high low switch when i isolate it. thought maybe normal. can anyone give me some idea why this would happen. i dont want to replace anything else till i can get more input. please help i need my bike for transportation and i get up early for work so i need my headlight.
Old Jul 1, 2009 | 07:02 PM
shardoflard's Avatar
take the switch apart. with something like that id take a picture b4 u examine things closely. just because theres a lot of parts in there.
Old Jul 2, 2009 | 03:54 AM
eweppley's Avatar
Take apart the right side controls and look at all of the electrical connections in there. I know it seems silly looking in there for a headlight problem, but the hot wire for the headlight goes through the starter switch on the way to the bulb. Mine was doing the same thing yours was too and a solder joint was broken in the starter switch. See if your headlight flickers when you turn the ignition on and wiggle the starter button. If it does, it's an easy fix with a little dab of solder. This seems to be a common F2 problem.
Hope this helps and good luck!!
Old Jul 3, 2009 | 09:26 AM
Dissevered's Avatar
+1
This is the problem. Happened to mine too. Just needs a bit of solder.
Old Jul 3, 2009 | 12:27 PM
jk72180's Avatar
ya happenned to mine. about 10 min and some solder and its been workin again for aver a month. it will be the third wire to the right.
Old Jul 6, 2009 | 08:21 AM
jfornoff's Avatar
thanks a lot guys i appreciate it. i will let you know if it works.
Old Jul 6, 2009 | 04:28 PM
jfornoff's Avatar
Talking
well you guys nailed it. that was the problem the whole time. thanks a lot guys it was better than going through everything else.
Old Jul 6, 2009 | 05:21 PM
Dissevered's Avatar
no problem, I'm glad you got it fixed.
Old Aug 14, 2009 | 11:05 AM
jfornoff's Avatar
Unhappy ok something else is going on.
i have the headlight problem again and it wont fix w/ just a little solder. i have resoldered it five times and that is just insanity. there is evidence of over heating of the wire in the start switch. i can go on a short ride and its ok but when i get home it it stops working. any one have a clue why it is overheating. i have checked for bare wires in the system cant find any. could a bad high/ low switch cause this to overheat the solder connection? i work w/ solder, and i have even tried high temp solder, and it still releases. any clue what would cause it to draw that many amps to unsolder????? Please help.
Old Aug 17, 2009 | 03:26 PM
jfornoff's Avatar
Exclamation
I need help with this
cmartino88
Aug 1, 2012 06:39 AM
papa wheelie
Jul 20, 2011 11:16 AM
Davidth93
Jul 16, 2009 12:22 AM
cyber00677
Aug 3, 2007 03:57 PM
