what RPM's should I be running at 55mph
Old 08-15-2009, 07:51 AM
mikee111's Avatar
Default what RPM's should I be running at 55mph
Hey Guys, I just got my 1994 F2 last month in July..I been riding alot and have noticed that at 55mph my tach reads at 5000 rpms in 6th gear.Is this normal? I have had numerous sportbikes in the past..but this is my first Honda 600cc bike.My old CBR 900RR ran like 4000 to 4500 rpms at 55mph.
It doesn't feel like my clutch is slipping....just checking with you guys to see if this is normal or not. Thanks
Old 08-15-2009, 11:30 AM
jamefs912's Avatar
My bike did that and come to find out my bike had an aftermarket sprocket kit on it. Check to see if you do. If you don't its not normal
Old 08-15-2009, 01:02 PM
Viking's Avatar
Mine runs at spot on 5000rpm at exactly 100kph (62mph) in 6th gear.
(original sprockets)
Old 08-15-2009, 01:26 PM
SJN's Avatar
SJN
SJN is offline
Select your bike here, and find out
http://www.gearingcommander.com/
Old 08-15-2009, 05:31 PM
deadsp0t's Avatar
sounds geared up to me. i went from 14-43 to 15-45 and mine runs along those same RPMs. also the tire size affects it( speedo calobration ) but link to gearing commander will sort all that out for you
Old 08-16-2009, 04:06 AM
jk72180's Avatar
bone stock my 93 runs at about 4900 at 60 in 6th
Old 08-16-2009, 04:59 AM
CaliKush's Avatar
just curious.. but why +1 in the front? i've heard that - 1 in the front is like + 3 in rear.. so if u +1 in the front is it like - 3 in the rear?
Old 08-16-2009, 06:51 AM
eweppley's Avatar
My F2 runs 55 at 5000 RPM in 5th gear. Your gearing is obviously not stock or you are counting wrong while upshifting...lol.
Old 08-16-2009, 11:25 AM
mikee111's Avatar
Thanks guys for the info, what is the stock gearing for a 1994 F2 ? I have a VORTEX 43 tooth on the rear.I need to pull the cover off and count the front sprocket today.The previous owner just put on a complete Vortex racing sprocket kit with chain before I bought the bike.I finally got a email from him about the gearing.
Old 08-16-2009, 11:32 AM
mikee111's Avatar
Is that right , 16/45 is STOCK for my F2..That gearingcommander.com is great!!!
Quick Reply: what RPM's should I be running at 55mph
