Headlamp issue once again
Old Aug 3, 2008 | 08:10 PM
LouSiffer's Avatar
Default Headlamp issue once again
replaced bulb/fuses, checked wiring no headlamp still. Ideas?
Old Aug 3, 2008 | 09:29 PM
pbrownw's Avatar
Default RE: Headlamp issue once again
check where you are getting power, check it at the headlight, fuse box and switch, my best guess would be a loose wire inside the switch pod
Old Aug 3, 2008 | 11:03 PM
LouSiffer's Avatar
we did all that and found I need a new throttle assembly switch and all. the electronics/switch inside is borked. Any ideas where to get a decent one cheap? if so hit me up.
Old Aug 4, 2008 | 07:14 AM
MikeInCtown's Avatar
eBay is your friend.
Old Aug 4, 2008 | 09:20 AM
pbrownw's Avatar
headlight switches are on the left side, so nothing to do with the throttle, and +1 on ebay
Old Aug 4, 2008 | 11:47 AM
diabloCBR15's Avatar
def the throttle side power switch. if the wires are not connected properly. you wont get any power to the headlight. i had the same problem before. definately ebay, but make sure you have the right year or else you might get stuck having to rewire stuff for an older model like i had to do cause the ebayer sent the older switch. good luck
blackN_yellowf4i
May 11, 2011 03:07 PM
Rockshoxtora
F3 Wanted
Aug 2, 2010 03:55 PM
Russell Norvell
Alternative Parts
Aug 18, 2009 08:35 PM
6zoomzoom6
Apr 14, 2009 09:22 PM
LouSiffer
Jul 7, 2008 01:28 AM
