head light is out
Old Jun 3, 2009 | 07:40 AM
city worker's Avatar
Default head light is out
Checked all the usual suspects, fuse, fuse block, bulb, nothing. The stange thing is when I did notice the lamp out I also noticed the High beam indicator light on the gauge cluster was out also (and I did check the rocker switch it was on high beam) I tested the wiring harness plug that plugs into the head light bulb and it is showing "no voltage" do I need to trace that wiring harness back to what ever it connects to?
Old Jun 3, 2009 | 07:44 AM
Viking's Avatar
Apparently the rocker switch is prone to failure (...or at least so i've heard).
I would start by inspecting that.
Old Jun 4, 2009 | 07:41 AM
I was told to check the hot that runs thru the starter button on the right side apperently thats where the head lamp gets its juice.
Old Jun 5, 2009 | 07:09 AM
Loose hot wire at starter swtich.
Old Jun 5, 2009 | 08:59 AM
Viking's Avatar
Nice! Enjoy your working headlight!
dizzle46
Jan 29, 2008 05:33 PM
serge1284
Jan 21, 2008 04:22 PM
djtrix92
Dec 12, 2007 04:54 AM
clean929
Aug 10, 2007 12:12 PM
Shlock
Oct 2, 2005 04:07 AM
