got some questions
the fuel *** on the side of the bike is up reserv and down on or what i know that middle is off and do the have a fuel filter on them and what are the 2 holes in the bottom of the tank side by side on my bike there are not hooked to any thing are they sapost to be please help
Yes,
Up- Reserve
Middle- Off
Down- On
One of the holes is for a over flow for your tank, aka if you fill your tank too high it will pee out that hole, it would prolly be a good idea for you to put a hose so it doesn't flow onto your engine if you ever overflow your tank, run it straight down to the ground.
I am pretty sure the other hole is a vac line to pull the gas. Dont hold me on that one though.
Hope that helps
Up- Reserve
Middle- Off
Down- On
Hope that helps
What year is your CBR? There should be 2 lines from the petcock 1 large and 1 small. Small is a vacuum line that runs from the fuel petcock to the #1 intake track on the cylinder head left side of the engine. That is for 91 to 94. The tubes off the back underside of the tank are over flow.
I think at this point, I'd siphon or pump the fuel out of the tank and pull the petcock and see whats up with it. There is a screen filter above the petcock, mine was nearly gummed completely up when I got my bike, and had some rust floating around inside to boot. [8D]
