Got my Trail Tech Vapor mounted on my F2 Fighter
Yes, I had my wife trace the fender with a marker. Then I took the dremmel and started hacking.
So far this is what I done.
[ul][*]Foam Brush painted the frame with rustolum stop-rust and sprayed the motor with 500* paint (clue how it will hold up)[*]filled dents in the tank and repainted also painted fender.[*]Install TT Vapor/w Custom mount[*]Custom ebay tail light /w custommount[*]Cut down the D&D exhaust[*]+5 Rear sprocket/w 520 chain[*]Fox Twin Click Rear shock[*]Demon head light fairing from www.flyncycle.com [/ul]
How that looks Awsome chris.I love that vapor Gauge.Can i replace my factory gauge with that and still keep my stock body?was it pretty easy to wire up?..Also that tail light is sick to..even those headlights are nice..!!Sick bike man good job..Got any other plans for it?
Trail Tech with the indicator dash was about $150 total. I am sure you could use it with full fairing, but you would have to build some sort of custom mount for it. Wiring is not bad if you have a little bit of skill. Took me a few hours to hook everything up. I didn’t even have to look at the wire schematic for the bike. I just traced all the wires for neutral, turn, oil.Speedo sensor was the easies part for me.
I think I am done for now. I just wanted a 2nd bike for terrorizing the neighborhood. It was a budget build. I have about $1400 total cost into the bike. My primary bike is a M109R.
