Fuel valve blocked??
Old 07-04-2011, 02:50 AM
rapidspec's Avatar
Default Fuel valve blocked??
Hi guys, hope you can answer this one for me as i,m a bit puzzled. I suspected no fuel was getting to my 94 F2 so i turned the valve to off, removed the 2 pipes attatched to the valve (the small vacume one from no 1 carb and the larger main pipe) There was plenty of fuel in the tank, well past reserve, anyway i turned the valve to the on position expecting the fuel to pour out , and nothing?? so i turned it to reserve, still nothing?? is this meant to happen? do i have a fault with the fuel tap?? I thought it was gravity fed or does it work with a vaccume? Baffled???
Old 07-04-2011, 03:36 AM
damuho's Avatar
In the ON position, fuel will flow through the bigger hose only when there is vacuum on the small hose that is connected to carb#1. You can unplug the hose from carb#1 and suck on it. If the petcock is operating properly, the vacuum you create will allow fuel to flow out of the bigger hose, into the carbs.
Old 07-04-2011, 05:10 AM
rapidspec's Avatar
thanks for the answer, did that and thats what happens previously so it is working properly. I seem to have a fuel delivery prob at carbs, maybe i should check pipe connections are sound and there are no air leaks at the air filter etc.
Old 07-05-2011, 03:44 AM
damuho's Avatar
Did you think fuel isn't going through because you can't start the bike? Are the carbs clean and is the choke working properly? I would be looking there first.
Old 07-05-2011, 01:52 PM
JesseAwesome's Avatar
Yeah, let's start with what brought you to suspect there was an issue, and we'll work from there.
cbrf2grrl
F2 Tech
14
01-28-2014 03:00 PM
Thaibiker85
05-11-2009 04:41 PM
j8k0092
07-04-2008 11:29 AM
gmay00
06-24-2008 11:27 AM
gmay00
05-11-2008 09:00 AM
Quick Reply: Fuel valve blocked??
