Fuel valve blocked??
Hi guys, hope you can answer this one for me as i,m a bit puzzled. I suspected no fuel was getting to my 94 F2 so i turned the valve to off, removed the 2 pipes attatched to the valve (the small vacume one from no 1 carb and the larger main pipe) There was plenty of fuel in the tank, well past reserve, anyway i turned the valve to the on position expecting the fuel to pour out , and nothing?? so i turned it to reserve, still nothing?? is this meant to happen? do i have a fault with the fuel tap?? I thought it was gravity fed or does it work with a vaccume? Baffled???
In the ON position, fuel will flow through the bigger hose only when there is vacuum on the small hose that is connected to carb#1. You can unplug the hose from carb#1 and suck on it. If the petcock is operating properly, the vacuum you create will allow fuel to flow out of the bigger hose, into the carbs.
