fuel leaking
Old Nov 8, 2020 | 12:01 PM
joelster69's Avatar
Default fuel leaking
Thx in advance ,
the bike drips gas from the bottom of carb#2 , only when the bike is running , and only when the gas tank switch on the on position , if I turn the tank dial to off, no drips.
was going to remove the carbs , but does it seem like a fuel hose going to the left side carbs?
I dont see a fuel pump like on my 89 f1
Old Nov 8, 2020 | 12:29 PM
joelster69's Avatar
figured the leak from a carb gasket was tore ,
now trying to put the carbs back on , need the proper procedure for the carb boots , mostly the orientation , etc
Old Nov 8, 2020 | 07:36 PM
The easiest way to remember is that the screws used to tighten the boots should be pointing outward
i find it easier to mount them on the carbs first.
Old Nov 8, 2020 | 07:40 PM
joelster69's Avatar
got them back on tight bike runs perfect! no gas leak , new batlaxes!
Old Nov 8, 2020 | 07:51 PM
Good deal. Glad you got her going
morbidphil0622
May 29, 2012 02:33 AM
APWCBR
Apr 22, 2012 02:27 PM
GotTatts
Apr 5, 2012 01:37 AM
sharkm87
Jun 18, 2011 09:31 PM
89cane
Nov 8, 2007 07:18 PM
