Front brakes
Old Mar 24, 2012 | 08:40 AM
blacken77's Avatar
Default Front brakes
Ok so last fall i put need front pads on my 93 f2 the left caliper seemed to be hung up was like that before i put the pads in... so over the winter i got 2 really good use ones cleaned them up checked the seals the look great installed them on the bike bled them out really good but it seems to me that there really tight im not sure what to do any ideas on what to do or what you may think thats going on thank you
Old Mar 24, 2012 | 01:18 PM
holyniht's Avatar
I just rebuilt my front calipers and if I were you I'd redo the seals just to narrow down the issue.. mines were pretty bad but changing them fixed my sticking issue
Old Mar 24, 2012 | 02:11 PM
74demon's Avatar
Are both calipers sticking or just one side? Make a mark with a crayon and roll it around to see which side wipes off. Do inside and out on the rotor.
If all 4 sides wipe off, your master is applied. If only 1 wipes off, look at the caliper binding.
Old Mar 25, 2012 | 09:01 PM
filthydanger's Avatar
check the torque on you axle. maybe it's too tight. should be 43ft/lb on the axle bolt. 16ft/lb on the axle pinch bolts. and 31ft/lb on your rotors. and 20ft/lbs on your caliper bracket.
Old Mar 25, 2012 | 09:46 PM
blacken77's Avatar
i will check the torque thank you
kdbolt70
Jul 3, 2012 12:55 AM
AlexF4i227
Mar 15, 2011 09:05 PM
KenG
Aug 31, 2010 05:20 PM
95HondaCBRF3
Sep 4, 2007 04:10 PM
brian97
May 8, 2006 10:45 AM
