Fork Oil Change
Old Sep 7, 2005 | 02:08 PM
CodeToade's Avatar
Default Fork Oil Change
Could someone please tell me the correct amount of fork oil for a '94 F2? The PDF service manual I have doesn't have any capacity specs, and I didn't get a manual with the bike.
Also, the SM seems to show the fork cap screwing up and out over the fork piston and adjuster. Mine gets to a certain point and stops. Is this the correct way, and I just have to twist harder? I've currently have the piston disconnected from the fork cap. Which is ok, but every time I move the fork I get a fountain of fork oil. So now I have to replace the fork oil. I wanted to get the fork working smoother for the track this weekend. Probably should try to align the top triple clamp also...
Thanks,
Steve
Old Sep 7, 2005 | 09:15 PM
92cbrf2's Avatar
Default RE: Fork Oil Change
15.7 oz according to the manual, i just changed the seal on my f2.
Old Sep 8, 2005 | 12:59 PM
CodeToade's Avatar
Thanks '92, I appreciate the info! I'll assume that's for both fork legs. IIRC either the VF or VFR had slightly different levels between the 2 legs. That should get me in the ball park anyway. If the fork leg is really bent the exact level won't be that critical!
Thanks again,
Steve
Old Sep 8, 2005 | 08:25 PM
92cbrf2's Avatar
the fork oil comes in 16 oz per bottle, I put the same amount on each leg. you should really get a manual if you work on the bike alot, I never worked on a bike before but the process want very smooth for me.
Old Sep 12, 2005 | 06:00 PM
CodeToade's Avatar
I downloaded the PDF manual that was going around sometime back. Unfortunately it doesn't seem to have complete info. Guess I'll have to buy a manual. Are the Clymer manuals any good, or can I get a OEM manual from somewhere?
BTW Traxxion recommends 140 mm with spring out and fork collapsed. That is somewhere around 18-19 oz, from what I saw the mechanic put in. Also got a lesson on how to assemble the forks. I used Mobil 1 ATF, recommended by many on the VFR list, and seemed to work well in the VFR. Now I have fork travel, but the triple is bent to heck and back... :-(
Doberman68
Jul 26, 2012 05:12 PM
mr93t
Jun 3, 2011 12:18 PM
tiger600
Oct 30, 2010 09:03 PM
driyac
Jul 11, 2010 02:40 AM
g32bturbo
Oct 25, 2008 03:29 PM
