f2 wont start, keeps fouling plugs
I bought an f2 the other day; the guy said he had it started earlier in the day but couldn't get it started again. I got a good deal on it though so I picked it up.
He said that the pilot screws may need adjusting because he messed with them when the bike was running too rich.
Here's what I did:
- tried starting it, would not go
- cleaned the plugs, they were too dirty not getting any spark
- tried again, wanted to go for a second but then stopped trying; the plugs were fouled again
- cleaned the plugs again and cleaned the carbs. changed the coils out
- tried again; once again, it wanted to go but fouled the plugs out again
Do I have something wrong with my carbs making them dump a bunch of fuel in or what?
Here's what I did:
Thats kind of what I was wondering, if the carbs being out of sync would make the bike not start at all.
I forgot to mention that only 3 plugs foul out, the number 4 plug will spark because it backfires out of the carbs when i pour gas down them
I had an f1 with similar symptoms... After I pulled about 3 pounds of dog food out of the air cleaner and tried starting it it cranked but didn't seem to want to fire up. Then CRACK it sounded like a shotgun going off... The wall behind the bike had a two foot circle of dog food, seeds, and every other thing that mice had packed in there. After the "obstruction" cleared the exhaust it ran great!
id rebuild the carbs. and change the plugs. what color is the foul? (pics?). depending on the color, can be the clue to your problem. ie, yellow is over heating... take a pic of the spark plug. and if its running way to rich it would fooul them up. and you said that the po did some thing to the carbs...
