F2 POWER BY 900RR
Old Apr 6, 2006 | 01:24 PM
Nipz's Avatar
Default F2 POWER BY 900RR
here is a link to the forum. I started it in 900RR.
https://cbrforum.com/m_83850/tm.htm
Old Apr 6, 2006 | 03:55 PM
rangerracer's Avatar
Default RE: F2 POWER BY 900RR
what year motor did he use?a friend of mine has a wrecked cb919 that we are thinking about doing this swap with.any info would be great
Old Apr 7, 2006 | 06:05 AM
Nipz's Avatar
they use a 93-95 893cc CBR900RR motor. not sure how the cb919 is but had to make engen mounts and a fuel pump because the carbs are higher then the bottem of the gas tank. they guy that set mine up is a pro welder so he did it all.
Old Apr 7, 2006 | 04:25 PM
the welding part is not a problem.it is what i do for a living.well he wants to much for his motor so i guess i will be hitting ebay for one.thanks for the info
Old Apr 8, 2006 | 07:53 AM
Nipz's Avatar
you have any other question just ask. if i see them i will give you some info or what i know.
Old Apr 9, 2006 | 12:38 AM
rafo!'s Avatar
which carbs did u use for the motor...............
Old Apr 13, 2006 | 02:22 PM
Nipz's Avatar
stock ones off the 893. the motor is all stock but a slip on.
The only problem it has is no room for a rad fan. i have a little area i can put on is like 6inch square. Any Ideas?
Old Apr 25, 2006 | 07:35 AM
MT Wallet's Avatar
the ultimate sleeper!
SEEYA7
Oct 26, 2010 07:13 PM
1badeg
Mar 11, 2009 03:24 PM
bigguns69
Mar 31, 2008 07:56 AM
Nipz
Apr 20, 2006 09:52 AM
NeonspeedRT
Dec 13, 2004 04:49 PM
