F2 PC25 and F4 ignition the same?
Old Mar 8, 2024 | 10:09 AM
Cuda's Avatar
Default F2 PC25 and F4 ignition the same?
TITLE WRONG AND CAN'T CHANGE IT, SHOULD BE F2 PC25 AND F3 ignition the same?
I'm pretty sure I asked this a couple of days ago in another thread of mine but got no answers so hopefully I "will to this. I have found a lock set from an F3 with both keys but need to know if the F2 and F3 ignitions are the same and if they are coded to the CDI control units if they are do I need the CDI control unit from the F3 with the ignition or will mine be usable with the replacement ignition? Answers would be greatly appreciated, thanks
Old Mar 8, 2024 | 06:35 PM
dannoxyz's Avatar
F2 doesn’t have security circuit.
F3 does have security circuit.
You can use F3 ign-switch with F2 ignitor.
You cannot use F2 ign-switch with F3 ignitor.
Old Mar 9, 2024 | 02:04 PM
Cuda's Avatar
Thanks Danno that's good to know at least now I can have faith that this is going to work ok after buying it, appreciate it fella
Old Mar 9, 2024 | 03:32 PM
dannoxyz's Avatar
You’re welcome! If pin-outs on connector doesn’t line up, we can de-pin and re-insert into working positions.
coldflood
Aug 17, 2011 11:31 AM
The_Prince_NR
F2 Tech
Mar 23, 2011 03:26 AM
aleos79
Mar 22, 2009 01:44 PM
