f2 missing at high rpm
Old Nov 8, 2007 | 05:43 PM
blettiere's Avatar
Default f2 missing at high rpm
Hey all,
Just got back fro a track day at Arroyo Seca in NM. Trusty F2 ususally does me right but this time it started loosing power at high rpms'. The day started fine, but later on, the bike would not reach redline before cutting out, almost like the reline had reduced itself. By the end of the day, it would not rev past 10k. It felt like hitting redline but it wasn't. Any thoughts as to what could cause this? Intial thoughts were that the valves needied adjusting.
thanks,
B
Old Nov 9, 2007 | 10:02 PM
FNQuickF2's Avatar
Default RE: f2 missing at high rpm
Valve adjustment wouldn't have that kind of effect immediately. Sounds more of either fuel starvation or the rev limiter somehow became askew..
RB
Old Nov 9, 2007 | 10:10 PM
notny41's Avatar
Put new plugs in.
Old Nov 10, 2007 | 08:07 AM
kjohnson's Avatar
Seafoam!! Always a good cheap fix/clean-up.
Old Nov 10, 2007 | 11:31 AM
notny41's Avatar
Yeah, you could try seafoam, but I don't think it is going to "cure" this one... Put new plugs in - I had a set in an FZR one time that sounded exactly like you are talking about. I tried everything including seafoam and yamaha fuel shock, etc. Talked to the yamaha dealer service department and asked if it could be the plugs..."nah, it's not the plugs" he said. I put new ones in anyway and it ran like it was friggin brand new.
Old Nov 11, 2007 | 10:20 PM
blettiere's Avatar
Appreciate the feedback. Planning to look into plugs and to make sure the coils are ok first before I do anything else.
thanks
Old Nov 12, 2007 | 11:51 AM
kjohnson's Avatar
Seafoam ain't a cure all,but for 6 bucks and change,it's hard to go wrong .
Old Nov 15, 2007 | 02:23 PM
blettiere's Avatar
As an update, I discovered that the regulator/rectifier (rr) was the culprit. It was getting ready to fail spectacularily.Doesn't always fail this way, but I have found at least one other person who had the same symptons I did.
moostadon
May 31, 2012 04:53 PM
kksdad
Oct 18, 2011 09:10 AM
mxpunk
Oct 20, 2008 02:14 PM
LC1
Dec 27, 2007 02:33 PM
Chris954rr
May 24, 2005 09:17 AM
