engine case crack
Old Jun 27, 2008 | 12:09 PM
Spieluhr's Avatar
Default engine case crack
Hey guys, went down on my bike on wednesday night. low-sided on my right side. When I got the bike up it was leaking a little bit of oil. It now seems to be fine when I run it, and the oil level looks ok.
but the leak started at the bottom of the beer bottle sized cover. in the attached picture (not my bike) you can see that this person had a scratch there as well. its the circle to the right of the transmission case.
http://inlinethumb23.webshots.com/18...425x425Q85.jpg
First off, what is this cover for? second, is it common for this to come loose and leak oil after sliding on its side? Think it's safe to ride now?
Old Jun 27, 2008 | 12:40 PM
SJN's Avatar
SJN
Default RE: engine case crack
Its the timing cover.
Inside, you can see the end of the crankshaft, and the sprocket with the cam chain. The Ignition pickup is also in there.
Old Jun 27, 2008 | 12:44 PM
Spieluhr's Avatar
ORIGINAL: SJN
ok, cool, thanks. is it common to be budged loose like this?
Old Jun 27, 2008 | 09:14 PM
Spieluhr's Avatar
ok guys, noticed a big crack in the timing cover case today, need a new one.
and I can't seem to find it in google, any help will get you an e-cookie
Old Jun 27, 2008 | 10:22 PM
SpecR's Avatar
I've got one.... pm me
Jet Jockey Z06 Vette
Jun 24, 2024 10:55 PM
The Situation
F2 Tech
Mar 21, 2010 02:15 PM
cjwill123
Jun 11, 2009 06:37 PM
meatpopsicle
Sep 18, 2007 07:10 AM
