Electrical problem!!!!!!!HELP
Hi, my bike was in hurricaine wilma. I spent $$$$ time repaired the starter changed plugs and the recitifer and ignitor box....worked for 1 yr now there is no spark to the plugs and I changed the ignitor box no change and I just changed the wiring harness in case it was corrosion and no change what could this be???? would the stator prevent spark to the plugs??? could it be the ignition coils????both at the same time???? help!!!!
Do you have the shop manual? If gives some tip to troubleshoot about this. I looked at it and it's a lot to retype, it's a scan of the book and not good enough for OCR to convert to text...
Here's the link to download the book.
Did you see that I posted the link to download it? I can save the images of the page and email them to you if needed.
Here's the link again.
Find the relay for the starter motor, there should be a multiplug, all the electrics go through that plug 1st the main fuse is also located in there too check it for corrosion..
give it a good clean and cover it in petrolium jelly
