Electrical
Old May 21, 2009 | 09:16 AM
meeson01's Avatar
Default Electrical
I need some help guys.
Yesterday, i was riding doin about 70 when i notice i have no thottle anymore....look down and i have no power....NOTHING!...so i pulll over..check the usual (kill switch, key, etc)..NOTHING..so i check the fuse next to the battery....its blown...luckily i had a spare...so i replaced it....still nothing....checked the ignition fuse....its fine...had to end up pushing the bike about half mile to a gas station so it was off the highway....bad day...any ideas?
Old May 21, 2009 | 05:26 PM
Phil314's Avatar
Loose connection at the battery, loose ground wire somewhere, or your battery just died.
Old May 22, 2009 | 06:30 AM
Syphen's Avatar
There isn't any rotten egg/sulphur smells is there? My reg/rect went one night while I was riding my F2 a couple years back and it actually was feeding my battery 25-30vdc. The battery boiled out everywhere and the bike died while I was riding. It stunk.
Old May 26, 2009 | 10:33 AM
meeson01's Avatar
I havent had a chance to really look closely at it...but i did tighten the connections on the battery and took a quick glance at the wiring...didnt see anything wrong...but i mean i only was there for like 10 min...i havent checked the battery yet but its only like 2 months old...but if the regulator is bad that would explain it i guess...any other ideas guys? thanks all
Old May 26, 2009 | 02:20 PM
g32bturbo's Avatar
regulator. same thing happened to me. spring for a new one. cheap, quick fix. if you have a multimeter, you can test your regulator.
Old May 27, 2009 | 01:57 PM
meeson01's Avatar
tested everything with the multimeter except the stator...but when i removed the rr and tested it i got a solid 1 ohm reading with allt he prongs no matter how i hooked it up to the ohmmeter....whats that mean? also i noticed a small hole in the flat soft rubber part of the rr...almost looks like it got hot and a bubble formed and popped....any ideas?
Old May 27, 2009 | 02:41 PM
Viking's Avatar
Sounds like your regulator is faulty.
(Oh and btw... no need to post the same question in several topics)
kani73
Jul 31, 2011 04:25 PM
zapp109
Apr 1, 2010 12:18 PM
drown42
Aug 26, 2009 04:06 PM
skitzofrenzy
Sep 22, 2008 04:21 PM
travsstuff
Dec 4, 2007 11:51 PM
