electrical
Old Jun 1, 2006 | 03:30 PM
Rog1's Avatar
Default electrical
Just recently i had to purchase a new rectifier and battery for my 93 F2 and now just one week later i've gone thruogh two batteries and two main fuse's. my guess is that i got a bad rectifer but im still new to riding still under 1K so if anyone else has any good guesses im open to the.
thanks
Old Jun 1, 2006 | 03:42 PM
suream's Avatar
Default RE: electrical
When does it blow the main fuse? How long is the battery in before it blows it?
Old Jun 1, 2006 | 10:29 PM
MT Wallet's Avatar
I had a lot of problems with my charging system.
- check rectifier
- check stator
-check wiring harnesses and all wires...make sure all are working right.
to know for sure take the bike to a mechanic and let them test the whole system
Old Jun 1, 2006 | 10:47 PM
Rog1's Avatar
it will usually work correctly any where from an hour to about a day
Rog1's Avatar
Old Jun 2, 2006 | 12:58 PM
Showtime3's Avatar
check stator. I had my rectifier changed and it works perfectly now.
Old Jun 2, 2006 | 09:49 PM
MT Wallet's Avatar
if your rectifier is bad it can affect your stator and vice versa.... best to get the whole system tested by a good mechanic
Old Jun 3, 2006 | 01:01 AM
Krokus_92F2's Avatar
If your installing a new battery, and your filling the electrolyte yourself, make sure you give the battery a good initial charge before popping it into the bike. If you don't, your electrical system will go into overload trying to charge the battery. Like the others said before me, it would be best to test your electrical system out.
Also check you wiring harness for burned connectors, around the rectifier and also believe it or not the headlight connection too. I have seen 3 F2's, including my own melt the headlight connector because the rectifier over charged everything. Your blowing fuses, that usually means a short.
kani73
Jul 31, 2011 04:25 PM
zapp109
Apr 1, 2010 12:18 PM
drown42
Aug 26, 2009 04:06 PM
skitzofrenzy
Sep 22, 2008 04:21 PM
travsstuff
Dec 4, 2007 11:51 PM
