EAMoto's 1994 CBR F2 Build
#21
I noticed in one of the first pictures the throttle "return" cable runs under the cross member that the coils are on and in the later pix it goes over the top. Does the throttle stick any? When I took mine apart it was ran over the top and it stuck. I've installed the carbs again, after a good cleaning, and after lubricating the cables it still sticks. With the cables hooked up and the carbs in my left hand (uninstalled) the throttle reacts normally but after I installed the carbs it sticks. I have the same semi sharp bend in the cable as you do. Which way is right?
#23
Yeah, I tried it with the return under and it stuck like a bastage! I took the time to take them off and lube them then put them back right and no problems.
#25
#26
I had to upgrade my photobucket account so some of you probably missed these updates.. I went over my limits with them...
We got everything mechanical finished up last week on her..
fork maintenance was finished up with new bushings and seals..
we replaced all the hardware on the tank as well as fresh race gas to help get all the build up out..
new Parts Unlimited battery works great!
Here is how she sits as of today..
#28
Latest Update: We ordered a brand new wiring harness from Honda hoping to fix it up right so we don't have any electrical issues on the road
#30
Latest Update:
I got the new wire harness in last week... then custom lights... custom tail section and custom blinkers... Thinking I may leave it half naked for now until I figure out what I want to do ...
