Dual headlight conversion
Old Sep 9, 2009 | 01:17 AM
amig's Avatar
Default Dual headlight conversion
hey guys,
was wondering if anyone knew of any diy write up about converting 1 headlight output to 2 on the f2
Old Sep 11, 2009 | 04:25 PM
G15OST's Avatar
Hey. All you need to do is splice a second headlight plug onto the orignal. Just make sure your joins in the wiring are soldered and insulated well and it'll work fine. I have done a few of these and never had a problem. The charging system has enough ummph to take it and the wiring wont overheat.
Old Sep 12, 2009 | 10:51 PM
amig's Avatar
thanks, my main concern was the regulator frying actually, i have two headlights which draw 35w each so itll be a 70 watt draw from the harness...but i think i may upgrade the regulator or add something to make it dissipate heat better.
Moore.Speed
May 10, 2012 04:08 PM
TheDouche
Mar 23, 2009 08:02 PM
kevdiggity
May 16, 2008 07:21 PM
gt2nv
Oct 31, 2007 09:40 PM
Purez
Oct 18, 2005 02:14 PM
