Dual seat conversion
Old Oct 30, 2008 | 10:12 PM
TheDouche's Avatar
Default Dual seat conversion
ok so i know theres been tons of rite ups about this but can someone give me a grocery list of parts need to convert from the banana to split seat?
im sick of chicks coming into my seat and crushing my stuff. god its annoying.
i herd the split seat isnt as comfortable as the banana. is that true? i was thinking to recover the seat when i get it so maybe i can add some stuffing or something.
any ideas on this or the grocery list? also i was thinking to get all new plastics seeing as learnign wheelies does a number on the plastics. who makes some good split seat plastics?
thanks!!!
Old Oct 30, 2008 | 11:34 PM
Xuracing's Avatar
Default RE: dual seat conversion
All parts come from a 01-03 F4i
Rear subframe
Foot Pegs
Rear Tail Cowl
Both front and rear seats
The undertail/Under tray portion
Tail lamp
Misc bolts and such
Anyone want to add anything that i missed?
Old Oct 31, 2008 | 12:50 AM
TheDouche's Avatar
if i got an undertail what part would that replace? i herd you need the battery tray no matter what?
can i reuse the 05 pegs or are they completely different?
Old Oct 31, 2008 | 12:53 AM
TheDouche's Avatar
i kinda like this undertail
http://cgi.ebay.com/ebaymotors/HONDA...mZ110303794473
Old Oct 31, 2008 | 03:28 AM
Xuracing's Avatar
i am not a fan of the single fan light i have one that is almost identical with two circle tail lights if you are interested
undertail just clean everything up so it doesnt look weird
Old Oct 31, 2008 | 12:29 PM
Stephens's Avatar
Me neither, for about 30 bucks more you could get one like mine. www.idealcycles.com
Old Oct 31, 2008 | 04:04 PM
808HondaLife's Avatar
The pegs will not work and the stock exhaust will not work also. You need the frankenstein bolts, the tank bolts, and the seat screws for the front seat.
Old Oct 31, 2008 | 07:08 PM
Xuracing's Avatar
ORIGINAL: 808HondaLife
what are you talking about. From the 03+ version or the 01 version. Why would you need different screws to screw in the front seats? it screws into the same Subframe it used to bolt on...
and why do you need tank bolts? The tank isn't even moving.
Old Oct 31, 2008 | 07:28 PM
TheDouche's Avatar
i have a yosh pipe so thats not too bad with exhaust. so the front seat is bolted down or is it latched?
Old Oct 31, 2008 | 07:41 PM
Aweasel's Avatar
ORIGINAL: Xuracing
it's simple
banana seat = no bolts
split seat = the front seat has 2 bolts towards the back that go into the subframe itself.
and 04+ is different, not 03+...03 models have the split seat
might consider this, since you have the bare aluminum frame...sandblast that **** before you put it on...looks like it belongs there.
I didn't order the special bolts from honda, the frankenstein bolts are like 16 bucks a piece, unless you ever intend on using a cargo net then just use regular bolts with washers. I went and picked up all the bolts I needed at a local auto parts store that sells stainless steel allen button screws.
for just mounting the exhaust the right side peg will work but not for riding passengers(lol)...for now I just bolted up that side using one bolt
