Does anyone make a Rebuild kit for the F2?
Old 07-08-2010, 06:27 PM
underground-mpyre's Avatar
Default Does anyone make a Rebuild kit for the F2?
Went to my local Honda shop today and asked about a rebuild kit for the F2. They gave me the whole deer in headlights look. They said I would have to purchase each part individually and probabley expensive too. Anybody make one?
I will need new valves, rings and probabley gaskets too by winter on how hard I ride.
Old 07-08-2010, 09:10 PM
Frank_F2's Avatar
All you need to buy is the engine gasket kit and any parts you need. (rings, bearings, valve seals, etc)
Old 07-08-2010, 10:27 PM
Surprising I haven't blown 2nd gear yet as hard as ride, a complete rebuild kit would save my motor time. Chicken strips are gone in 2 days on my tires. Valves, gaskets, rings and bearings going on 30K and have felt my wrath. If I make it to winter is a gamble. A Worse part is this majority is a daily commuter everywhere, unless rain in riding season. All I need is a kit to get it all done in one sweep. Any Help???
Old 07-09-2010, 12:26 AM
halffast1g's Avatar
I havent rebuilt this bike. I take it most people just spend a couple hundred dollars and buy a used motor from another bike.
Old 07-11-2010, 11:18 AM
jk72180's Avatar
wiseco makes a big bore kit
http://www.orientexpress.com/Honda/S...252F618cc.html
little pricy though
Old 07-11-2010, 11:35 AM
Project96's Avatar
There is no rebuild kit like there is on small block chevy or fords. You need to buy a gasket kit. Whats wrong with the valves? Is one of them starting to suck into the head? If not the valves should be ok. If not let me know I have a spare head sitting in the garage ready to bolt on. Valve seals & piston rings would be recommended. I would also recommend the honda bond HT gasket stuff. Dont use some rtv from your local parts store. Other than that you should be good.
Old 07-11-2010, 11:41 AM
JesseAwesome's Avatar
What exactly is involved with the big bore piston kit? I imagine you'd have to machine some parts of the motor correct?
Old 07-11-2010, 11:51 AM
Project96's Avatar
Since the cylinders are part of ther cases. The cases will need to be split, head removed, & pistons removed. Then when you get the new pistons take the pistons & upper case half to a machine shop & have the cylinders bored & honed to size. 636 is as big as you can go on the stock sleeves.
Old 07-11-2010, 12:09 PM
The work isn't as huge of a deal, it's the additional hidden costs. I wonder what a machine shop would want.
I guess the good news is that the kit includes new pistons and rings. Not only will there be a power gain, but anything lost due to the rings fading will come back
Still... that's $1000~ rebuild! Yowza!
Old 07-11-2010, 12:50 PM
Browntowns20s's Avatar
every now and then there is a rebuild kit on ebay, but for the cost it would be easier for you to ride it till it blows, and then replace the whole thing. I for example have another engine just laying around waiting for its chance to shine and you can find them all over the place for a fraction of the cost of boring it over and all of that, and if you bore over your bike your gonna introduce a whole new can of worms to the mix... so i would just let it blow or buy a newer bike
Quick Reply: Does anyone make a Rebuild kit for the F2?
