Do the Problems ever stop.... Need some help
Old Apr 16, 2009 | 08:23 PM
kpnupe's Avatar
Default Do the Problems ever stop.... Need some help
I replaced my voltage regulator with a new aftermarket one with fins hoping that it would fix my problem of my bike dieing after a long ride. So today during a 20min ride(first one with the new VR) my bike dies on the highway. I pull over and push start it and about after 3rd try the bike comes on. As im riding i turn the high beams on and the bike dies again. I switch them off then the bike turns back on. Im at the point where i dont know what to do. Any help would be greatly appreciated.
Also the battery was fully charged before i left and now the headlights are dim when i turn the key..
Old Apr 17, 2009 | 12:45 PM
g32bturbo's Avatar
where did you get the regulator from?
Old Apr 17, 2009 | 01:08 PM
kpnupe's Avatar
ebay..
http://cgi.ebay.com/ebaymotors/ws/eB...t_12687wt_1201
im going to see if this problem continues with the old one as well. since it didn't happen before..
Old Apr 17, 2009 | 04:13 PM
g32bturbo's Avatar
why'd u replace it then?
Old Apr 17, 2009 | 06:01 PM
kpnupe's Avatar
The battery would die after long rides even when it was fully charged. So i assumed after reading some post that this was the problem.
Old Apr 18, 2009 | 01:23 AM
Squamish CBR's Avatar
sounds to me like the battery has packed it in. I noticed with my '94 that the batteries are not too robust; I overcharged mine and wreaked it. The VR might have damaged it. I bought a good quality Yuasa and it has lasted for several years with the stock VR. The trick is not to get sucked into throwing parts at it. Switching to high beam probably put the current demand just that little bit over the top and pulled the voltage down to the point where the ignition would no longer work. What is the voltage when the bike is running? Do the stator continuity checks as outlined in the manual it is either good or it's not. If your VR uses the factory spade connectors take a screwdriver and tighten them right up; that is where my problem was; the loose connections created heat and that takes out the diodes in the regulator. Good luck!
Old Apr 18, 2009 | 01:26 AM
Oh yeah do a good search for loose connections at the battery and the main feeds to the fuses.
Old Apr 18, 2009 | 10:14 AM
Sand.Man's Avatar
continuity checks, troubleshooting:
https://cbrforum.com/forum/f2-tech-93/charging-issues-troubleshooting-testing-91252/
malbojah
Oct 19, 2010 09:37 PM
brokencbr
Mar 17, 2009 05:53 AM
jaynd
Sep 28, 2008 09:27 PM
champ24
Apr 11, 2008 10:37 PM
old1000
Jan 10, 2007 12:52 AM
